Question About Valves For Plumbing. - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-09-2010, 03:05 PM   #1
Question about valves for plumbing.
I'm about to replace the pipe from my house to the water meter and I am wondering if it would be better to use a 'gate', or 'ball' valve, for the shutoff next to the house.
The weather is too cold right now for me to find out what type of valve I have but, since it's been in the ground for 20+ years, I thought it would make sense to replace it.
Your suggestions will be appreciated.
TIA.
Lewis.
Limeylew is offline   Reply With Quote
Old 01-09-2010, 05:58 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,628
Above grade or buried,..?? If exposed, Ball valve is the hands down Winner...
Bondo is online now   Reply With Quote
Old 01-09-2010, 07:15 PM   #3
GC/Master Plumber/Mech
Rewards Points: 560
I always use 1/4 turn ball valves unless specs or building plans dictate different
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 01-10-2010, 07:01 AM   #4
Ball Valve
SULTINI is offline   Reply With Quote
Old 01-10-2010, 09:15 AM   #5
Inspector/Instructor
codeone's Avatar
Ball Valve less problems!
codeone is offline   Reply With Quote
Old 01-10-2010, 09:34 AM   #6
Gate valves have lost their appeal. Too many things can fail on them, including the gate sticking or dropping off. Even valves for underground use on water supply lines are now a ball type (1/4 turn). They have a raised piece on them to accept a special wrench for operating them.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 01-10-2010, 10:35 AM   #7
Re: Question about valves for plumbing.
Thanks for the help guys, I really appreciate it.
Kind regards.
Lewis.
shutoff valves all leaking hohadcr Plumbing 1 08-01-2009 06:38 AM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
pex valves rtoni Plumbing 2 02-24-2009 03:34 PM
Honeywell Utica Boiler Valves Question cmariorussell HVAC 2 02-03-2009 09:54 PM
hrv question indep HVAC 3 07-17-2008 10:39 PM
