Question About Shower Valve? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-23-2008, 04:38 PM   #1
Question about shower valve?
All....
I am about 80% done with demolition of a stall shower (walls done - floor next) - house is 60 years old so lots of tile, concrete, and wire mesh - was truly a mess to do - anyway - I would like to install a shower head and a handheld unit on a sliding bar on a separate wall....so I have been looking at Kohler MasterShower - the supply lines are 1/2"....and a 40gal water heater ... so no body sprays ... I am looking at the Kohler K-680-KS combo valve - temperature and volume control ... I guess my question is does the valve have the ability to control water flow to each shower head...or just one - do I need another flow control valve...? I have been studying what I have found on the Internet without an answer....Thanks for your help....much appreciated....!
Rick
Rick Bruner is offline   Reply With Quote
Old 03-23-2008, 10:42 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
I believe it will only supply to one head at a time.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 03-23-2008, 11:06 PM   #3
Ron...
Thanks much....I know it will only supply one at a time - but can I switch between the two using that same valve (i.e. can it do that or do I need another valve)....?
Thanks again,
Rick
Old 03-23-2008, 11:09 PM   #4
Journeyman Plumber
If you add a diverter valve, so you can switch to which ever one you want
Misbehaving shower mixer valve ranagnos Plumbing 6 03-03-2008 08:24 PM
shower valve doesn't "mix" moneymgmt Plumbing 9 01-23-2008 10:45 AM
aging symmons temptrol shower valve v240969 Plumbing 1 01-01-2008 06:24 PM
Bathroom shower sill installation question bocci Remodeling 2 07-23-2006 01:31 PM
Shower stall question... Alan Remodeling 1 05-31-2006 07:57 AM
