Question About Septic Pump & Alarm Wiring. - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-01-2012, 06:41 PM   #1
US ARMY RETIRED
ACR_SCOUT's Avatar
question about septic pump & alarm wiring.
I started digging a trench from the house to the septic pump tank to install wiring for an alarm. The pump wire comes to a weather box on the outside of the tank. The wire from the house comes out of the ground to that box. The wire from the box going into the ground is standard romex. About 10 underground it is spliced into underground cable and taped up.
I want to replace this wire all the way back to the main panel and add the wire for the alarm. I want to run it all in plastic conduit. Can both wires run in one conduit or do I need to run two different ones. Is there a better way to do this?
Thank you,
Fred
ACR_SCOUT is offline   Reply With Quote
Old 02-01-2012, 06:50 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Both can be put in conduit. Just go big enough on the conduit so you can pull the wires with ease
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 02-01-2012, 08:02 PM   #3
Rewards Points: 582
I believe both can go into same ... you may consider 2-pipes though just in case there is ever a problem..pull acouple extra for power and for alarm....
Old 02-04-2012, 03:38 PM   #4
US ARMY RETIRED
ACR_SCOUT's Avatar
Question
Ok. I need to clean this up a little now.
Here is what I think I want to do until someone tells me otherwise.
I am going to get a control and alarm box by SPI (50B010) <http://www.septicsolutions.com/PDFs/...es%20sheet.pdf>
In that box is a 20 amp breaker for the pump. I know I have to rewire this from the main panel out to the tank so I took a look at the current wiring which is 14/2 romex with a 15 amp breaker in the main panel.
I have a Zoller 153 half horse power pump.
I believe I am going to run 12/2 underground cable from the main panel to the new control panel. Currently I know of two splices in the current cable. One in the basement in a junction box and one buried about 10" under ground.
Does anyone see any flaws in my plan?
Is 20 amps too much to protect the Zoller pump?
Thank you,
Fred
Old 02-04-2012, 03:43 PM   #5
Rewards Points: 560
If you are going to put this in conduit then there is no reason to use UF cable or cable for burial. But if you are going to direct burial then you need to use UF. Using 12/2 w/ground romex in conduit is fine
20a breaker is fine as well. No splices under ground or in the conduit.
Other than that sounds like you have it all together
Old 02-04-2012, 03:46 PM   #6
US ARMY RETIRED
ACR_SCOUT's Avatar
Smile
After the price comparison and the distance I have to run the wire outside. It actually comes out cheaper to run UF 12/2 with ground all the way. I just need to find some Duct Putty
Thank you.
Old 02-04-2012, 03:50 PM   #7
Rewards Points: 560
Sometimes price dictates what you can or have to do and I can understand that. But using condit is sooooooo much better. It protects the wiring and its easier to replace if something goes wrong and the wiring needs to be replaced.
How deep are you buring the wire?
You should go atleast 24" and at the 1 ft depth as you are back filling place yellow caution tape the length of the trench. This way if someone digs they will hit the caution tape and know that wiring or piping is below.
Old 02-04-2012, 04:12 PM   #8
Rewards Points: 582
yes arc seem like you got a good grip on what your going to do ...just courious what the max amp rating is on pump????
Old 02-04-2012, 04:19 PM   #9
US ARMY RETIRED
ACR_SCOUT's Avatar
[QUOTE="Plumber101"
You should go atleast 24" and at the 1 ft depth as you are back filling place yellow caution tape the length of the trench. This way if someone digs they will hit the caution tape and know that wiring or piping is below.[/QUOTE]
I think code says 24" that is what I was plannin. The yellow tape is brilliant. I will do that.
I will look again at the conduit idea but from the tank to the foundation wall is 17 feet. The previous post says I can't splice conduit under ground. Seems strange since I have to put a fitting on the pvc conduit to bring it up the foundation wall.
Fred
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
New heat pump wiring question jmedenf HVAC 3 10-14-2011 06:26 PM
SUMP PUMP Question Stevera64 Plumbing 5 08-09-2009 07:43 PM
Well Pump to Generator Question Sprice Electrical 1 02-11-2009 11:27 AM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 09:10 PM
