Question About PVC Saddle Tee - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-25-2008, 04:29 PM   #1
Question about PVC Saddle Tee
I want to tap into my 3" PVC sewer pipe with a 2" vent pipe on one spot and then a 1-1/2 drain for a shower on another section. I'm comfortable with using a saddle T for the vent pipe but not sure if the solvent/clamp type of saddle T is acceptable for actual waste/grey water.
Advice?
Doozer is offline   Reply With Quote
Old 08-25-2008, 04:45 PM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
Advice?
Are you sure you got this right, 2" vent with a 1-1/2" drain for shower. Here we must drain showers with 2" let us know if you posted correctly.
Old 08-25-2008, 05:28 PM   #3
Your right. I actually have 3 seperate taps but only concerned about two that are in very tight spaces. I have a 2" vent and a 2" drain for shower. I have another tap that is a 1 1/2" for a sink but thats easy enough to actually splice into the 3" line.
My concern is more using a saddle T for the 2" drain.
Old 08-25-2008, 06:01 PM   #4
Send a message via AIM to Marlin
You have to come into your waste line with a wye, a tee can not be laid on it's back.
Marlin is offline   Reply With Quote
Old 08-25-2008, 07:44 PM   #5
Whatamess
If the pipe is accessible cut the pipe and do what you need and reconnect with a hubless repair union or 3" rubber union.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
hrv question indep HVAC 3 07-17-2008 11:39 PM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 10:10 AM
New service Question Onytay Electrical 1 10-24-2007 06:47 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 11:17 PM
