Question About PVC Drain Pipe (shower) - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-12-2012, 02:04 AM   #1
Question about PVC drain pipe (shower)
Hi all.
Started a bathroom/shower remodeling today and I completed most of the demo. However, it seems my new shower pan is about 3" wider than the previous tub-most everything else is fine as far as alignment goes, but the PVC drain pipe is about 2-3" off center towards the right (if you're facing the drain wall).
I can pull on the pipe and there's enough wiggle room where I can get the pipe to align with my shower's drain area, but it's pretty tight and I have to exert quite a bit of pull to get it there. Wondering- should I do this for my final installation? Will prolonged torquing cause the PVC pipe to crack prematurely in the future?
Thanks all.
nighthawkix is offline   Reply With Quote
Old 08-12-2012, 08:37 AM   #2
Rewards Points: 12,794
Not going to work.
Going to have to cut and rebuild that drain so it lines up with out having to force it.
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 11:53 PM
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 12:53 PM
Utility sink drain pipe question jabergess Plumbing 3 05-06-2011 09:01 AM
removing Cast Iron drain pipe jimmyfloyd Plumbing 1 01-04-2011 04:47 PM
Pipe offset in shower drain RWThrun Plumbing 4 07-30-2009 07:03 AM
