-   -   Question about PVC drain pipe (shower) (http://www.diychatroom.com/f7/question-about-pvc-drain-pipe-shower-153380/)
nighthawkix 08-12-2012 01:04 AM
Hi all.
Started a bathroom/shower remodeling today and I completed most of the demo. However, it seems my new shower pan is about 3" wider than the previous tub-most everything else is fine as far as alignment goes, but the PVC drain pipe is about 2-3" off center towards the right (if you're facing the drain wall).
I can pull on the pipe and there's enough wiggle room where I can get the pipe to align with my shower's drain area, but it's pretty tight and I have to exert quite a bit of pull to get it there. Wondering- should I do this for my final installation? Will prolonged torquing cause the PVC pipe to crack prematurely in the future?
Thanks all.
http://i.imgur.com/2WSHH.jpg
joecaption 08-12-2012 07:37 AM
Not going to work.
Going to have to cut and rebuild that drain so it lines up with out having to force it.
