#1 |
Question about Plumbing Basement bathroom with PEX
Hello Everyone,
I figured this would be a good place to ask a question regarding my basement bathroom install so here is goes. Our home has existing copper pipes and I would like to run PEX lines for the basement bathroom. I will have a vanity, shower and toilet. Would it make sense to run a hot & cold line to the bathroom with a shutoff valve at the copper and PEX connection. Then put a 3 way out manifold inside the bathroom wall or ceiling that would feed the the toilet, sink and shower? Or am I better off runing the manifold at the copper & PEX connection and running additional lines for each. Any opinions on the sharkbite PEX tubing and fittings from home depot? Thanks alot for any help |
#2 |
i would put ball valves at where you tap into copper preferably 3/4" and then plumb like it was copper but in pex of course
sharkbite are ok the cinch clamps i prefer since one tool crimps all sizes and easy to cinch in tight spots
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are 1 poop needs to flow down hill. 2 hot on left cold on right 3 i get a pay check on Mondays 4 do not chew finger nails at or after work. |
#3 |
I studied and studied and studied pex for my basement bathroom addition and in the end decided to use copper.
I didn't like the crimper for the fact you have to keep it calibrated. I liked the expander, but the box stores don't carry the supplies. If you are in the trade it may be worth it, but for my small projects i will stick with what I know. B |
#4 |
Civil Engineer
Ditto on the crimper, I am not sold on the need to calibrate. I use Wirsbo tubing and fittings, which of course requires the expansion tool, sold only at plumbing supply stores, not the big box stores.
#5 | |
call me E
Question about Plumbing Basement bathroom with PEXQuote:
When posting in forums, letting us know your location will help others give better feedback/advice/solutions to your questions |
#6 |
i have never had to recalibrate my ring clincher but i use the viega pureflow press all most always now. due to no calibration and bronze or poly fitting both for the dezincification
| Display Modes | |
| Bathroom addition in attic to basement drainage | tmtoddsr | Plumbing | 3 | 05-16-2011 08:21 PM |
| Adding Basement Bathroom. Rear discharge toilet install question | paulyjsob | Plumbing | 6 | 03-29-2011 03:55 PM |
| Basement Bathroom Circuit | PJ33P | Electrical | 1 | 02-12-2011 08:13 PM |
| Old Home - Basement addition insulation vapor barrier question | 1870 | Building & Construction | 0 | 10-14-2010 08:36 AM |
| Framing Question: How thick the wall that carries plumbing? | jaes | Carpentry | 5 | 06-18-2008 06:39 PM |
