-   -   Question about Plumbing Basement bathroom with PEX (http://www.diychatroom.com/f7/question-about-plumbing-basement-bathroom-pex-136286/)
dgreen 03-07-2012 11:14 AM
Hello Everyone,
I figured this would be a good place to ask a question regarding my basement bathroom install so here is goes.
Our home has existing copper pipes and I would like to run PEX lines for the basement bathroom. I will have a vanity, shower and toilet.
Would it make sense to run a hot & cold line to the bathroom with a shutoff valve at the copper and PEX connection. Then put a 3 way out manifold inside the bathroom wall or ceiling that would feed the the toilet, sink and shower? Or am I better off runing the manifold at the copper & PEX connection and running additional lines for each.
Any opinions on the sharkbite PEX tubing and fittings from home depot?
Thanks alot for any help
jaydevries 03-07-2012 10:40 PM
i would put ball valves at where you tap into copper preferably 3/4" and then plumb like it was copper but in pex of course
sharkbite are ok the cinch clamps i prefer since one tool crimps all sizes and easy to cinch in tight spots
Beepster 03-08-2012 10:15 AM
I studied and studied and studied pex for my basement bathroom addition and in the end decided to use copper.
I didn't like the crimper for the fact you have to keep it calibrated. I liked the expander, but the box stores don't carry the supplies.
If you are in the trade it may be worth it, but for my small projects i will stick with what I know.
B
Daniel Holzman 03-08-2012 11:15 AM
Ditto on the crimper, I am not sold on the need to calibrate. I use Wirsbo tubing and fittings, which of course requires the expansion tool, sold only at plumbing supply stores, not the big box stores.
TheEplumber 03-08-2012 11:36 AM
199 Attachment(s)
You guys take the calibration too seriously. The tool remains calibrated for so long that you often misplace the gauge :laughing:
jaydevries 03-08-2012 03:28 PM
i have never had to recalibrate my ring clincher but i use the viega pureflow press all most always now. due to no calibration and bronze or poly fitting both for the dezincification
