Question About Installing Plastic Sink Basket - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-19-2010, 09:57 PM   #1
DIY Expert in Training!
Question about installing plastic sink basket
I am finally wrapping up my kitchen overhaul. Tonight I installed the sink basket. I used plumbers putty to form a ring. I then tighten the ring below the sink as much as possible. Sink the inside of the drain is plastic I cannot use a screw driver or plyers to hold it solid so I can crank it down. I have some back and forth play. How do I get this tighter without breaking the basket?
Just to clarify...here is a pic of my sink and basket
Thanks!
gone_fishing is offline   Reply With Quote
Old 06-19-2010, 10:47 PM   #2
DIY staff
Rewards Points: 7,174
Believe it or not--there is a tool for that!
It looks like a 4 inch long piece of galvanized tubing with four notches in one end and a T-handle at the other end.
Old 06-19-2010, 10:49 PM   #3
DIY staff
http://www.google.com/imgres?imgurl=...26tbs%3Disch:1
Old 06-19-2010, 11:50 PM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
First question to you : Why are you installing a plastic one?
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
oh'mike (06-20-2010)
Old 06-20-2010, 07:32 AM   #5
DIY staff
This is a good lesson on why cheap costs more----Poor quality materials --
1-Take longer to install
2-Often break or fail to function during installation
3-Don't fit well or look good
4--Seldom last as long as a quality part
5-the failure damages or destroys something else costing 100 times the "savings" when you bought the cheap part.
Gone fishing--this is not aimed at you personally--Just a heads up to others.
That tool will cost more than a good metal sink basket--Which you could have held with a set of plier handles-----Mike----
Old 06-20-2010, 10:00 AM   #6
I was burnt out at the end of a long day when I installed that basket. Heading to the store to buy a good stainless basket now along with other parts I need. Thanks for the advice all!
The Following User Says Thank You to gone_fishing For This Useful Post:
Old 06-20-2010, 12:22 PM   #7
Doing it myself
Alan's Avatar
Get one like this with the big cup underneath.
http://www.google.com/products/catal...CAgQ8gIwADgA#p
They are much easier to tighten, and later when you have to pull them off due to corrosion or putty washout, or whatever, they are easier to take off.
Journeyman Plumber
gone_fishing (06-20-2010)
Old 06-20-2010, 01:24 PM   #8
Alan, if I didn't get that exact model I got it's twin. It was super easy to install and tighten up.
Installing a pedestal sink on slate? britt_schaeffer Plumbing 2 09-28-2009 10:16 PM
Installing utility sink next to washer/dryer cuseguy Plumbing 2 12-30-2008 06:09 AM
installing a pedestal sink???? auron Kitchen & Bath Remodeling 3 12-28-2008 11:13 AM
Problem installing pedestal sink... gone_fishing Plumbing 6 04-15-2008 09:32 AM
Novice question: Installing windows in wood sided home...(pic) Dr. Jim Building & Construction 5 07-06-2007 07:33 PM
