Question About Fire Sprinker Alarm System - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-14-2012, 03:42 PM   #1
Rewards Points: 37
question about fire sprinker alarm system
i have a question about this sprinkler alarm system.
Here is a pic of what i have:
I am trying to tap into this water line for my RO/DI unit in the garage (for my fish tanks). I just want to make sure its ok to do so.
So the red box senses water flow (certain rates/time) and sets off the fire alarm. I'm guess it only senses water flow that goes past the red box. The "T" that splits off before the red box goes to a pressure gauge and then down to the lever (closed) which allows to let water out thru the wall out to the yard to flush water. I'm guessing the thing to the right of the pressure gauge is some sort of safety valve that opens once it hits a certain pressure.
There is a valve down below the main thick pipe. is it ok to turn that off and drain the sprinkler system so i can work on adding another valve for my RO/DI?
joshik is offline   Reply With Quote
Old 12-14-2012, 04:23 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 682
You probably don't want to tap into that system. That is black iron pipe and full rust, cutting oil, etc. It is not potable. Someplace near there should be a double check assembly or other approved backflow device. You need your connection on the potable side of that assembly.
Old 12-14-2012, 07:08 PM   #3
Rewards Points: 582
as eplumber said probablydon't .....let me say.... don't tie into that system period.....ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
TheEplumber (12-14-2012)
Old 12-15-2012, 04:10 AM   #4
Rewards Points: 37
cool, thanks for the info!!!! my poor RO/DI unit would had a heart attack.
What about tapping into the cold water line into the water heater? I'm thinking it would be safe to add a T to the cold water supply line to the water heater. From the T, i was going to put in a pressure regulator for drip irrigation systems so I can keep a max pressure of about 40psi then PVC to my RO/DI unit.
Any thoughts?
The Following User Says Thank You to joshik For This Useful Post:
ben's plumbing (12-15-2012)
Removing a home alarm system box bbarney Electrical 5 07-03-2012 07:06 AM
Fire alarm cable for speaker wire? helpless handyman Electrical 6 04-03-2012 12:07 AM
New AC System Question flysndoc HVAC 3 09-22-2008 06:34 PM
Outdoor Fire Pit Question fishers3 Landscaping & Lawn Care 1 05-04-2008 07:34 PM
Carport to Garage: Fire barrier question Grommet Remodeling 2 03-28-2008 04:18 PM
