Question About Filing Screw In Steel Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-22-2013, 03:40 PM   #1
Hi everyone. I have a quick question about a steel pipe. There is a small nail or piece of metal sticking out in the middle of the pipe. I need to stick a piece of PVC pipe into it for a project that I am doing and it looks like the screw is about 6 to 10 inches away from the end of the pipe.
What would be the best way to get rid of it? What sort of file could I use?
I am ultimately looking for the cheapest way for me to get rid of it. I don't really care if it takes about 20 minutes for me to file it down by hand but more than 20 would be too much. Any suggestions? Thanks.
jmsheldon is offline   Reply With Quote
Old 02-22-2013, 03:47 PM   #2
Rewards Points: 13,458
Ok, so what is running through this pipe? water gas ECT.
And how does PVC come into play?
Old 02-22-2013, 03:48 PM   #3
I am just using it as a pole mount for a solar panel. The pvc pipe will go through the steel pipe but it can't with the screw in the way.
Old 02-22-2013, 04:01 PM   #4
Rewards Points: 994
Drill it out. If the hole remaining isn't tolerable plug it with something like JB weld.
Old 02-22-2013, 04:02 PM   #5
Grind it foor with a right angle grinder, a hack saw. About a 5 min. job.
Old 02-22-2013, 04:08 PM   #6
I might of forgotten to mention that I can't reach the outside of the pole. I can only get rid of it from the inside of it and it is still 6 inches in from the end (just measured it). The pole is small, 2" inside diameter, so I can't fit any sort of electric grinder in it.
Old 02-22-2013, 04:14 PM   #7
I'm thinking of ordering this now and picking Saturday delivery: http://www.amazon.com/Nicholson-0660...productDetails
Will it work?
Old 02-22-2013, 04:24 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 564
Will it work?
Why not go down to your local hardware store and get it- support your local economy and get it done today
Old 02-22-2013, 04:41 PM   #9
My local hardware stores don't usually have what I need. I went to Lowes and they didn't even have a few of the things that I need. Either way, I would rather pay nine bucks more to get it tomorrow. None of my local hardware stores are that close to me anyways.
Thanks.
Old 02-22-2013, 04:49 PM   #10
Good luck with trying to file it out. Just drill it out and be done with it.
Any local hardware, or box store would have that simple file.
Old 02-22-2013, 04:57 PM   #11
I told you I can't drill it out because I can't get to the outside of the pole. The pole is under my deck and got cut off and capped off. I am not sure if it is even a screw or not. But it is definitely metal because I cannot get the PVC pipe into the steel pole.
Old 02-22-2013, 06:16 PM   #12
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,060
Ayuh,.... Use a big punch, 'n a BFHammer, 'n Bust it off.....
Bondo is online now   Reply With Quote
Old 02-22-2013, 06:37 PM   #13
Roofmaster
Rewards Points: 2,172
Buy a hole saw that fits the inside dimension, A Mandrel that fits a speedbore extension, and a speedbore extension with a spring collar.
The Following User Says Thank You to jagans For This Useful Post:
Davejss (02-23-2013)
Old 02-22-2013, 09:25 PM   #14
If you do end up with a file use a rat tail, or 1/4 round file not a rectanguler file.
Round pipe, round file.
Old 02-22-2013, 09:38 PM   #15
I understand this but I actually want to leave a portion of the screw in because it will help stabilize the PVC pipe since the PVC does not fit perfectly into the steel pipe.
Tags
fence , pipe , post , pvc , steel
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
Steel to PVC vent pipe john_bry Plumbing 2 10-28-2012 06:10 PM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 11:27 AM
Using sharkbite to fit leak in pipe...pipe hole size question. RyanD Plumbing 4 08-14-2009 06:17 PM
buried galvanized steel pipe amakarevic Plumbing 6 06-23-2009 02:15 PM
