-   -   Question About Filing Screw In Steel Pipe (http://www.diychatroom.com/f7/question-about-filing-screw-steel-pipe-172673/)
jmsheldon 02-22-2013 03:40 PM
Hi everyone. I have a quick question about a steel pipe. There is a small nail or piece of metal sticking out in the middle of the pipe. I need to stick a piece of PVC pipe into it for a project that I am doing and it looks like the screw is about 6 to 10 inches away from the end of the pipe.
What would be the best way to get rid of it? What sort of file could I use?
I am ultimately looking for the cheapest way for me to get rid of it. I don't really care if it takes about 20 minutes for me to file it down by hand but more than 20 would be too much. Any suggestions? Thanks.
joecaption 02-22-2013 03:47 PM
Ok, so what is running through this pipe? water gas ECT.
And how does PVC come into play?
jmsheldon 02-22-2013 03:48 PM
I am just using it as a pole mount for a solar panel. The pvc pipe will go through the steel pipe but it can't with the screw in the way.
SeniorSitizen 02-22-2013 04:01 PM
Drill it out. If the hole remaining isn't tolerable plug it with something like JB weld.
joecaption 02-22-2013 04:02 PM
Grind it foor with a right angle grinder, a hack saw. About a 5 min. job.
jmsheldon 02-22-2013 04:08 PM
I might of forgotten to mention that I can't reach the outside of the pole. I can only get rid of it from the inside of it and it is still 6 inches in from the end (just measured it). The pole is small, 2" inside diameter, so I can't fit any sort of electric grinder in it.
jmsheldon 02-22-2013 04:14 PM
I'm thinking of ordering this now and picking Saturday delivery: http://www.amazon.com/Nicholson-0660...productDetails
Will it work?
TheEplumber 02-22-2013 04:24 PM
199 Attachment(s)
Will it work?
Why not go down to your local hardware store and get it- support your local economy and get it done today :thumbsup:
jmsheldon 02-22-2013 04:41 PM
My local hardware stores don't usually have what I need. I went to Lowes and they didn't even have a few of the things that I need. Either way, I would rather pay nine bucks more to get it tomorrow. None of my local hardware stores are that close to me anyways.
Thanks.
joecaption 02-22-2013 04:49 PM
Good luck with trying to file it out. Just drill it out and be done with it.
Any local hardware, or box store would have that simple file.
jmsheldon 02-22-2013 04:57 PM
I told you I can't drill it out because I can't get to the outside of the pole. The pole is under my deck and got cut off and capped off. I am not sure if it is even a screw or not. But it is definitely metal because I cannot get the PVC pipe into the steel pole.
Bondo 02-22-2013 06:16 PM
Ayuh,.... Use a big punch, 'n a BFHammer, 'n Bust it off.....
jagans 02-22-2013 06:37 PM
Buy a hole saw that fits the inside dimension, A Mandrel that fits a speedbore extension, and a speedbore extension with a spring collar.
joecaption 02-22-2013 09:25 PM
If you do end up with a file use a rat tail, or 1/4 round file not a rectanguler file.
Round pipe, round file.
jmsheldon 02-22-2013 09:38 PM
I understand this but I actually want to leave a portion of the screw in because it will help stabilize the PVC pipe since the PVC does not fit perfectly into the steel pipe.
