Old 05-05-2009, 03:56 AM   #1
Question about Adding toilet to basement
Hey all,
I live in a town Home. I currently have 1 bathroom in my house. I'm looking to add another bathroom in my basement and also finish the basement while I'm at it. I have a sewer pipe that runs down (vertically) the north side of my house, pretty much down the middle of one of my walls. in my basement I can see there's an access hole about 6 feet up from the ground, I wanted to know if I can use a saniflo system and connect to that access hole?
Also I don't know where my Vent system is, so where do I connect the Vent pipe?
I'll post a pic of my basement pipe if needed.
Steve
dasaint80 is offline   Reply With Quote
Old 05-05-2009, 05:27 AM   #2
Of course Im not there to see exactly what you have there but the pipe sounds like your main drain line that drains the entire house to the sewer system and the capped hole would be the "clean out", the access used to auger out any clog. In my opinion you could not use the clean out as the toilet connection but instead would have to establish a connection to the drain somewhere above that point. Additionally you have failed to address 2 other main issues, where is your water supply coming from? and how are you going to vent the toilet? Both of these issues could be a real challenge in a townhouse. The water supply might be the easiest to find but the likelihood that your existing vents would be large enough to add another toilet is very slim. Sounds like you need to consult a professional plumber to see if this job could be done at all. Good luck
faucetman886 is offline   Reply With Quote
Old 05-05-2009, 08:30 AM   #3
if the acces is above the concrete you will have to bust out the floor to adda bath if I am understanding correctly. post some pics so we can better understand
al's sewer is offline   Reply With Quote
Old 05-05-2009, 03:51 PM   #4
here's a link to the pics of the pipe I wanted to connect to for toilet.
steve
Old 05-05-2009, 05:55 PM   #5
Theres is too much involved here for me to try and explain to you how to do this. My opinion...call a professional plumber and get the job done right according to your plumbing codes and regulations.
Old 05-05-2009, 08:27 PM   #6
JDC
Plumbing Contractor
JDC's Avatar
Thats a cast iron stack and you're going to need cast iron soil pipe cutters to get into it. It's very heavy and can be dangerous if not supported properly during the cut. What you are wanting to tie into is indeed a cleanout and not a good point of connection. Besides, you dont need a connection point that big anyway.
As far as the vent goes, is there other plumbing already in the basement (laundry tub, washer box, etc)? If so follow the piping from the trap first vertical pipe going upward. Assuming this IS the vent (hard to tell since I'm not there looking at it) you can tie in there. If there is no plumbing in the basement, you're going to need to run a vent up through the floor into a wall where such a vent exists.
Water will probably be the easiest aspect of this project as even if you have no fixtures existing in the basement, your waterline most likely enters your home there.
My advice is to at least have a consultation with a plumbing contractor who can evaluate the feasibility of this project.
Good luck and keep up posted.
JDC is offline   Reply With Quote
More On This Topic
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. One thing to remember when plumbing your basement, is that the location of the toilet is not as important as it first may seem. Where that pipe is sticking... Read More »
Hi, I'm Jeremy Blackwell I'm here today to help you get started on your basement remodel project. This is a GFCI outlet that's required in bathrooms. The reason this is required is because if any water were to just drip on the outlet or if a hair dryer... Read More »
Before you buy a house, it is a good idea to either inspect it yourself or hire a professional to do it for you. If you do not know what to look for, you may end up with repairs and problems you did not expect. Here are some tips on how to inspect... Read More »
We are going to talk a little bit about our waste lines and our vent lines right now. The waste line being when you turn the sink on and the water that falls into the sink, where does it go, well it goes right down into this pipe here, travels down the... Read More »
Hi this is Andrew Jenkins on behalf of expertvillage.com. Now in this clip I'm going to be telling you about pipe cleaner crafts specifically how to make a nice little pipe cleaner flower like this. Now pipe cleaners flowers are one of the most popular... Read More »
Basement Toilet Rough In - Help atm Plumbing 3 06-06-2009 12:04 PM
New toilet in basement altadata Plumbing 1 02-10-2009 12:53 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
