Question About 3 Knob Diverter - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-30-2010, 04:09 PM   #1
Question about 3 knob diverter
I have an older shower with a 3 knob diverter. There is a trickle of water that comes out from the cold water tube into the tub when the shower is on. The odd thing is that this water comes out from the cold side tube een when only the hot water is on.
I am demoing this entire setup and installing a stall shower so I am not looking to fix this issue, but I am curious about it. Why would both hot and cold water come thru the tube?
Lockeset is offline   Reply With Quote
Old 10-01-2010, 06:02 AM   #2
The diverter valve is basically the same as the other valves. Rebuild it it with a new washer, and O rings if it has them.
Old 10-01-2010, 03:20 PM   #3
I'm not looking to fix it, just to understand why water would leak out from the cold stem tube even if only the hot water is turned on.
Old 10-03-2010, 02:42 PM   #4
Bump!
Old 10-10-2010, 07:20 AM   #5
No one knows about this oddity?
knob and tube question marin001 Electrical 7 12-21-2008 03:49 PM
GFCI Question Nealndar Electrical 2 09-13-2008 05:15 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Flush Mount Volume Knob to Vinyl Siding fatdan777 Remodeling 4 07-24-2008 12:04 PM
hrv question indep HVAC 3 07-17-2008 10:39 PM
