Old 10-04-2011, 10:21 AM   #46
Doing it myself
Alan's Avatar
PVC vs. Copper from Water Meter
Originally Posted by vcheez View Post
some kid could be riding his bike down the side walk and wipeout on curb and bust my PVC elbows near the meter since they are only about a foot deep.
I can assure you sir, that if your line is properly bedded, this situation will NEVER EVER occur.
Journeyman Plumber
Old 10-04-2011, 10:25 AM   #47
Doing it myself
Alan's Avatar
I just noticed a picture of the bonding to the copper piping.
I'm no electrician, but something in our code requires that bonding be moved to an appropriate location when the water main is non-metallic.
Something to look into.
Journeyman Plumber
Old 10-04-2011, 11:29 PM   #48
The copper pipe is bonded between the ground at my service panel and 10' ground rod. If you notice from my picture there is loop in the grounding terminal. This is because one half of the loop is connected to the electrical service panel ground and the other end of the loop is connected to the 10' earth ground rod. The ground rod maybe 8' long. It's been a few years since I installed it and I forgot which one we installed.
vcheez is offline   Reply With Quote
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
Routing of water pipe from street to meter John Reynolds Plumbing 0 05-24-2011 02:23 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
Basement water meter below floor level redfox1 Plumbing 5 12-10-2008 09:20 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
