Old 10-04-2012, 11:58 PM   #1
PVC trap adapter on galvanized trap?
I am putting a new tub in my bathroom, which includes a new tub drain kit.
The existing plumbing is 1/2" galvanized. The tricky thing is that the trap is right above some ductwork so there is limited space to work with. The end of the trap is 1 1/2" galvanized male. I need to connect my 1" plastic tub drain adapter to this. My first plan was to do this using two PVC adapters: a threaded female 1 1/2" to unthreaded female 1 1/2", connected to a male unthreaded 1 1/2" to 1" trap adapter. These connections would all fit, however, when I use this, the drain is about 1" too high for the tub.
If I were to eliminate the adapters and just use the screw-on part from the PVC trap adapter and use it to attach the tub drain kit to the galvanized trap, this will allow the drain to be low enough. This is how the original construction was done, but the adapter and the tub drain were also both galvanized.
is this appropriate? Screwing the PVC trap adapter "nut" straight on to the galvanized trap? Or should I be worried about mixing materials in this case?
dougan is offline   Reply With Quote
Old 10-05-2012, 12:27 AM   #2
Missouri Bound's Avatar
It's fine. If you are unsure, check the threads on the adapter and the pipe....exactly the same. Teflon tape will help with the installation.
Do you want it your way or the right way?
Old 10-05-2012, 07:16 AM   #3
Only thing to worry about is the fact that old steel pipe needs to be replaced because it rust out from the inside where it can not be seen and is at some point going to leak and close up on the insides reducing flow.
Missouri Bound (10-05-2012)
trap adapter kyleraup Plumbing 2 11-08-2011 10:10 AM
Trap Adapter Leak? kcrossley2 Plumbing 6 01-27-2010 01:55 AM
1 and 1/2" trap adapter for 2" drain pipe maxfischersweet Plumbing 5 11-19-2009 11:33 PM
firring out concrete wall for electric and insulation trouble Building & Construction 9 02-04-2009 12:40 PM
P Trap & Galvanized Pipe Catchinyellows Plumbing 4 11-11-2008 11:22 AM
