-   -   PVC trap adapter on galvanized trap? (http://www.diychatroom.com/f7/pvc-trap-adapter-galvanized-trap-159007/)
dougan 10-04-2012 10:58 PM
I am putting a new tub in my bathroom, which includes a new tub drain kit.
The existing plumbing is 1/2" galvanized. The tricky thing is that the trap is right above some ductwork so there is limited space to work with. The end of the trap is 1 1/2" galvanized male. I need to connect my 1" plastic tub drain adapter to this. My first plan was to do this using two PVC adapters: a threaded female 1 1/2" to unthreaded female 1 1/2", connected to a male unthreaded 1 1/2" to 1" trap adapter. These connections would all fit, however, when I use this, the drain is about 1" too high for the tub.
If I were to eliminate the adapters and just use the screw-on part from the PVC trap adapter and use it to attach the tub drain kit to the galvanized trap, this will allow the drain to be low enough. This is how the original construction was done, but the adapter and the tub drain were also both galvanized.
is this appropriate? Screwing the PVC trap adapter "nut" straight on to the galvanized trap? Or should I be worried about mixing materials in this case?
Missouri Bound 10-04-2012 11:27 PM
It's fine. If you are unsure, check the threads on the adapter and the pipe....exactly the same. Teflon tape will help with the installation.:thumbsup:
joecaption 10-05-2012 06:16 AM
Only thing to worry about is the fact that old steel pipe needs to be replaced because it rust out from the inside where it can not be seen and is at some point going to leak and close up on the insides reducing flow.
