PVC Through Brick To Outdoor Tap - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-17-2016, 11:50 AM   #1
Rewards Points: 2
PVC through brick to outdoor tap
Will spare the details (will want to start drinking if I go into it)-
but previous owner of house had someone repair a leak to outside tap... and this person replaced the piping heading to the tap with PVC.
So if a person want to use the hose/ tap, you must very cautiously, but firmly, grasp the 2" of PVC protruding from the brick to stabilize things while turning on the faucet (which, of course, is metal).
Also, the person who made this repair mortared around the pipe (I guess because he had taken out 5-6 bricks to make the repair to begin with)...
I am amazed that the pipe has survived this long without cracking.
Is there anything that can be done to correct this without ripping out the brick and replacing the PVC?
mbdugas is offline   Reply With Quote
Old 06-17-2016, 05:06 PM   #2
Rewards Points: 2,634
Re: PVC through brick to outdoor tap
Most spigots have a flange on the face to mount to the wall, as shown below. If your spigot does not have a mounting flange, replace it. You could make a spacer out of PT wood -- mount the wood to the brick, and the spigot flange to the wood.
But if you would prefer to have copper, I don't see why you would be doing anything to the brick. Cut the PVC pipe and rip it out. Its not going to stick very well to mortar, and if worst comes to worst, you could drill the old pipe stub out -- its only PVC.
SPS-1 is offline   Reply With Quote
Old 06-17-2016, 05:09 PM   #3
Rewards Points: 1,770
A long masonry bit 1 inch then a wood bit 3/4 inch should do the trick.
Old 06-17-2016, 05:26 PM   #4
Don't even need the masonry bit.
3/4" PC is 1.050 OD --- 3/4" copper is .875 OD -- only need to cut thorough plastic.
Similar situation if its 1/2" PVC
Pros please help - what method attach porch roof to brick veneer dinoburger Concrete, Stone & Masonry 6 08-02-2015 11:57 AM
Cleaning & Sealing Red Brick JasonCA Concrete, Stone & Masonry 3 01-23-2013 12:56 PM
Brick veneer is 4 rows below grade- redo or leave? cbrc5eric Building & Construction 11 12-27-2011 09:09 PM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 09:50 AM
Sealing historic brick tenzo General DIY Discussions 2 11-22-2008 04:04 PM
