PVC Support? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-06-2012, 08:24 AM   #1
PVC Support?
My inspector said that my PVC waste lines need rigid support to prevent "bounce".
Here's what they look like now:
http://imgur.com/SeRfe
What should I use? Could I just drop down some lengths of 2x4 and use that same metal banding that you see in the photo (what is proper name for this)?
Or do I need some kind of special piece (link?) to make the inspector happy?
Thanks!
tomsmyth is offline   Reply With Quote
Old 11-06-2012, 08:55 AM   #2
Rewards Points: 13,274
http://www.engineeringtoolbox.com/su...pes-d_790.html
Old 11-06-2012, 09:21 AM   #3
Rewards Points: 3,130
I believe the metal banding is called plumber's tape. It also comes in plastic (a lot cheaper). It's what I used in my house.
Old 11-06-2012, 10:05 AM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I don't know what code you're working out of, but ours only specifies that it shall be supported, not HOW it shall be supported.
Did he red tag you for it?
2x4 with plumbers tape is the way we do it most of the time now.
Journeyman Plumber
Old 11-06-2012, 10:27 AM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 452
Plumbers tape is not good enough in some areas Use these- or Allen's method- basically the same concept http://www.siouxchief.com/Support/DW...rs/XP5JY.XP5JY
Sunroom extension support footings repair + cost gentlemansbeard Building & Construction 11 03-25-2011 03:40 PM
Alterative ways to support main beam frizbplaya Building & Construction 8 01-29-2011 12:10 AM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 09:38 PM
Basement Metal Support Post virgolibranyc Building & Construction 4 09-07-2010 04:07 PM
moving a support wall 6 ft over.? help jstamps Building & Construction 1 04-20-2010 06:48 AM
