Old 07-03-2010, 03:53 PM   #1
South Jersey
PVC supply line for sprinkler system
I plan on installing an automatic sprinkler system. I have a 5/8" water meter that then goes into a 3/4" brass elbow and then to 1 inch PEX tubing for the water supply to the house.
I plan on having a plumber come in and install a tee fitting and valve for me even though I'm confident I could sweat whatever I needed. My question is, can I run 3/4" PVC from the back-flow preventer to the sprinkler valve manifold? The distance of the run would probably be around 20ft and it is in my basement until it goes outside to the manifold.
Just curious if 3/4" PVC would be acceptable or if it should be 3/4" copper pipe.
Reddhead is offline   Reply With Quote
Old 07-04-2010, 01:10 PM   #2
Just call me Andrew
I have heard on this forum from people that PVC shouldn't be used inside. When we installed the system for my parents, we used 1" copper untill it left the house, then we converted to pvc before going into the ground to the valve box. After the valves, we used 1" black poly.
Andrew
secutanudu is offline   Reply With Quote
sealing around copper water supply line dazedanconfused Building & Construction 4 09-22-2009 05:55 AM
Capacity loss with line size Einride HVAC 1 06-29-2009 04:10 PM
can I connect PB or Pex supply line to barb with clamp? grgryl Plumbing 11 08-20-2008 05:11 PM
add an additional register to a supply line b2v HVAC 1 06-20-2006 07:55 PM
hot pilot light supply line dlkk HVAC 1 02-24-2006 06:45 PM
