PVC To Stainless - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-30-2006, 06:03 AM   #1
Rewards Points: 150
PVC to Stainless
Can you connect PVC to a stainless tail pipe. I have a PVC wasteline coming up from the basement and connecting to the kitchen double bowl sink which has stainless tail pipes. It leaking and I need to fix it.
econdave is offline   Reply With Quote
Old 04-30-2006, 10:14 AM   #2
I do not think that you have stainless. It may be copper with a chrome outer layer.
Are both the PVC and the "stainless" the same size? Should be either 1- 1/2" or 1- 1/4".
You can either use a rubber connector with metal holding clamps or you can use a pvc compression fitting that will usea rubber washer inside of the the fitting. This rubber washer will compress around the "stainless" and give you a tight seal.
redline is offline   Reply With Quote
Old 04-30-2006, 06:51 PM   #3
Contractor
Whatever your tail is, there should not be a problem.
Teetorbilt is offline   Reply With Quote
Old 05-02-2006, 05:58 AM   #4
Rewards Points: 150
thank you, got it all back together and no leaks. Great forum and great info.
stainless sink/countertop for food co-op arise Plumbing 1 06-15-2007 10:27 AM
Current trends: Cast Iron or Stainless Steel sink? Fat b Remodeling 4 05-04-2007 07:09 PM
Gauge of stainless steel sink Not Sure Plumbing 2 08-29-2006 04:56 AM
Stainless chimney liner relining systems Lisalovespainting HVAC 2 08-09-2006 05:48 AM
Dented stainless steel-HELP!!! yrapps Remodeling 4 05-09-2006 04:22 PM
