-   -   PVC to Stainless (http://www.diychatroom.com/f7/pvc-stainless-2387/)
econdave 04-30-2006 06:03 AM
PVC to Stainless
Can you connect PVC to a stainless tail pipe. I have a PVC wasteline coming up from the basement and connecting to the kitchen double bowl sink which has stainless tail pipes. It leaking and I need to fix it.
redline 04-30-2006 10:14 AM
I do not think that you have stainless. It may be copper with a chrome outer layer.
Are both the PVC and the "stainless" the same size? Should be either 1- 1/2" or 1- 1/4".
You can either use a rubber connector with metal holding clamps or you can use a pvc compression fitting that will usea rubber washer inside of the the fitting. This rubber washer will compress around the "stainless" and give you a tight seal.
Teetorbilt 04-30-2006 06:51 PM
Whatever your tail is, there should not be a problem.
econdave 05-02-2006 05:58 AM
thank you, got it all back together and no leaks. Great forum and great info.
