PVC Sink Drain Pipe... - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-30-2011, 10:11 AM   #1
Rewards Points: 242
PVC sink drain pipe...
Question about PVC. I am building a stud wall...in my bathroom. It's a wet wall..or half of one. My house was built in the early 50's and has two back to back 2x4 walls forming a wet wall between the two adjoining bathrooms.
Problem...the waste pipe connection, where the sink drains connect, is not parallel to the stud wall that I'm building. So, instead of the sink drain pipes passing between the stud walls with minimum cutout, the sink drain, a 1-3/4 inch galvanized sink drain pipe, angles through the studs. The cutouts needed to accommodate the angled drain pipe are enormous...and from what I see...severely damage the studs, compromising their integrity.
This is a 7X5 foot bathroom...so we're talking about two studs...the same studs that I will cut out for an in wall medicine cabinet. These are the only two studs on that side of the room.
My question...is...finally. Since I'm replacing the galvanized pipe with PVC, is there a way that I can correct the angle, short of cutting off the stack and putting in a new one? Flexible, or angle...heat and bend.
I'm up for suggestions...
I would appreciate any help. I would like to be prepared to offer suggestions to my plumber when he comes out to stub in the fittings.
Ed911 is offline   Reply With Quote
Old 11-30-2011, 02:16 PM   #2
Can you post a picture?
Billy_Bob is offline   Reply With Quote
Old 11-30-2011, 07:14 PM   #3
Rewards Points: 242
Sure, but it'll be tomorrow...thanks,
Ed
Old 11-30-2011, 09:13 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 354
As a general rule, heat should not be applied to the pipe- but I have seen it done. If the angle does not run the pipe out the wall, I'd go ahead and notch the studs, then put plywood on the side of the studs so it sisters to the stud on the other wall and perhaps a horizontal block here and there. All this is assuming the wall is non bearing of course
The Following User Says Thank You to TheEplumber For This Useful Post:
ben's plumbing (11-30-2011)
Old 12-01-2011, 11:09 AM   #5
Rewards Points: 242
Sistering to the other wall's studs would be a good idea, if they were plumb, and I wasn't planning on renovating/repairing the other bathroom...which isn't in good shape. So, I really can't do that...although, good idea...thanks.
Question: What size PVC is used these days for sink drains in bathrooms? Just wondering.
Thanks,
Ed
Drain For Garage Sink & Standing Pipe Fire4Effect Plumbing 4 09-29-2011 12:16 AM
Utility sink drain pipe question jabergess Plumbing 3 05-06-2011 09:01 AM
AC Coil drain pipe questions fritzycat1 HVAC 14 11-12-2010 04:51 PM
sewer backup and stench jayhill Plumbing 12 08-14-2008 12:06 AM
Water from sink backs up in stack pipe. droy Plumbing 5 01-24-2008 07:39 PM
