PVC Roof Vents - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-11-2009, 04:56 PM   #1
DIYer
PVC roof vents
When investigating a leak, I noticed that my roof vents are just white PVC stubbed up though the roof.
Is this considered OK? I thought white plumbing PVC brittled in UV light
Gigs is offline   Reply With Quote
Old 05-12-2009, 05:31 AM   #2
Some PVC gets brittle and yellows in sunlight and in cold. I have read here that plumbing PVC is more UV resistant than the stuff I use for vac lines. Check the stamping on the pipe, then google it or post it here.
Chemist1961 is offline   Reply With Quote
Old 05-12-2009, 06:24 AM   #3
Rewards Points: 150
Its fine ...find something else to worry about.
al's sewer is offline   Reply With Quote
Old 05-12-2009, 10:00 AM   #4
The vent piping is the same pipe throughout your house. It has been approved for vent/exposed usage.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Roof Vents j_fricke Roofing/Siding 3 05-22-2008 11:07 AM
