PVC Primer Clean-up - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-05-2005, 11:13 AM   #1
PVC Primer clean-up
PLease help! After installing a new fiberglass bath tub and tiling the wall, I had to adjust the depth of the shower curtain head and cut a piece of PVC... Long story short, when I repaired the shower head a little of the Purple PVC primer dripped on the tub and won't come off... Needless to say my wife is P/O'd. Any help on getting this stuff off? Thanks,
George
supergeorge1025 is offline   Reply With Quote
Old 06-05-2005, 09:58 PM   #2
Contractor
Contact the company. I'm guessing that Acetone will be your remedy. If you are really lucky and the release film is still on the tub, denatured alcohol may do the trick.
Teetorbilt is offline   Reply With Quote
Old 10-27-2005, 10:20 PM   #3
Go to plumbing supply (not Lowes,HD) ask for Hercules Hands wipes. They're like baby wipes but for harder chemicals. I once had a helper drop a can in front of a tub and the mess was unbelievable. It took him about 2 hours but you couldn't tell.
Your little spot shouldn't take but a few minutes scrubing with those.But not sure effectiveness if it has been a while.
nipltwstr is offline   Reply With Quote
Old 10-27-2005, 11:05 PM   #4
jproffer's Avatar
Rewards Points: 716
Use clear primer next time
jproffer is offline   Reply With Quote
Old 10-29-2005, 10:45 AM   #5
Long-Time DIYer
Mike Swearingen's Avatar
Nail polish remover (acetone type) also should do it.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 11-27-2005, 03:32 PM   #6
PVC Clean-up
I also got some pvc primer on fiberglass tub. Got almost all of it off, but pits were left in fiberglass with purple showing in pits. Any ideas about repairing small pits in fiberglass?:confused:
Matt48 is offline   Reply With Quote
Old 11-28-2005, 06:37 AM   #7
Long-Time DIYer
Small pits and scratches in fiberglas tubs can be repaired with white enamel touch-up liquid made for repairing appliances. I've used it for years.
It dries a bright white, like enamel appliance finishes, but it dries hard as a rock. It's available at most appliance stores, etc. It comes with a little cap brush applicator like nail polish.
Clean and dry (I use a hair dryer) the pits thoroughly, and dab a bit of touch-up liquid on the spot. Clean up the edges with a Q-tip dipped in acetone (nail polish remover).
Let it dry overnight. It will shrink a bit. Apply a second coat if necessary.
Good Luck!
Mike
Old 11-10-2009, 09:00 PM   #8
perfect for clean up
Goo-B-Gone xtreme you can get it at walmart you cant even tell it was ever there after u use that stuff
jstew is offline   Reply With Quote
clean chimney jckkcj General DIY Discussions 13 08-25-2012 05:56 PM
old primer firsthomegal Painting 2 06-21-2007 08:28 PM
Primer for MDF? NateHanson Painting 13 05-09-2007 09:09 PM
Is it normal for primer to show thru dark paint on first coat? Autumnknight Painting 5 10-02-2006 06:38 AM
