Pvc Pipe Under Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-27-2010, 11:45 AM   #1
pvc pipe under sink
the connection with the bottom section of the PVC pipe "T" keeps coming apart. I've had it tightened several times, and it keeps coming off, spraying water all over when it leaves the sink. Can you help me? Do I need goop? The plumber says tightening it should help, but it does nothing for me.
Nancy
Nancychef1 is offline   Reply With Quote
Old 09-27-2010, 04:01 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
PVC sink drain pipe traps are made to be hand-tightened. There is a beveled washer under the nut. Make sure that it is turned in the right direction or it will leak and prevent the nut from tightening properly.
If all else fails, smear a little clear silicone caulk around the washer under the nut before tightening it.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
The Following User Says Thank You to Mike Swearingen For This Useful Post:
Nancychef1 (09-29-2010)
Old 09-27-2010, 07:48 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 562
Consider lowering the tee a bit by making the vertical tailpieces longer
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 09-29-2010, 09:25 AM   #4
lowering the tee
I'm not sure what you mean by "lowering the tee"? Could you explain more?
Old 09-29-2010, 09:27 AM   #5
what direction should the beveled nut be? toward the threads or away?
Nancychef1
Drain Pipe about 20 Inches to the right of Vanity Sink mark2741 Plumbing 2 12-16-2009 10:32 AM
Leaking kitchen sink drain pipe zasior Plumbing 10 01-11-2009 07:22 PM
Caulking around kitchen sink deeaa Remodeling 8 07-13-2008 03:12 PM
Kitchen sink recommendations? pweller Plumbing 4 07-08-2008 08:43 AM
reducing pipe size for sink drain bluebee1314 Plumbing 5 12-02-2007 12:53 PM
