PVC Pipe Spacing In Trench - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-09-2013, 02:29 PM   #1
Rewards Points: 18
Question
PVC pipe spacing in trench
I am installing a large irrigation system. All pipes are PVC. The trench is about 8" wide and 12" deep. I have a 1 1/2" main irrigation line and a 1" PVC conduit for sprinkler wires running together. In some places, there are also one or two 1" PVC pipes carrying water after valves. So, in the worst case, there can be 4 PVC pipes in the same trench: (1) 1 1/2" PVC and (3) 1" PVC.
My question is how to best place these 4 pipes in the same trench. If I knew I would never dig it up and fix anything again, I would not care. But, chances are there will be a need for future digging/fixing/or just tapping into one of those pipes. When that happens, it will a nightmare to cut a pipe if the others are too close it.
Can I use PVC spacer? Does anyone has experience spacing PVC pipes? Any recommendations?
yilmazma is offline   Reply With Quote
Old 04-09-2013, 05:15 PM   #2
Rewards Points: 1,676
Use pex it is very resistant to freeze breaks.
Old 04-09-2013, 05:52 PM   #3
Rewards Points: 6
Where are you located? 1 1/2 is pretty big for supply lines. Is your water main that big? I would use Polyethelene pipe instead of PVC. It goes in faster and you don't have to mess with glue, just crimp clamps. You can rent a machine that will slice your lawn and pull the poly pipe at the same time. It leaves little evidence you did anything. The only digging you'll need to do is for the heads.
Best way is to bring the supply into a valve box and supply a manifold consisting of the zone valves. Do you have a drawing of what you have planned?
Dan
djlandkpl is offline   Reply With Quote
Old 04-09-2013, 06:17 PM   #4
Rewards Points: 18
I am located in San Francisco Bay Area. We usually don't have freeze here. Lowest temperature I have seen was 36 F.
I already have the PVC pipes, so other pipe options is not an option for me. The irrigation system will be used for fruit orchard drip system as well as lawns. The total irrigation area is about 1 acre. Supply line is 2" sch 80 PVC. The 1.5" irrigation main line will be pretty long: about 1200 ft.
There will be 16 drip irrigation zones and 6 sprinkler zones. There will be 8 valve boxes distributed in this area. Almost every tree gets its own drip riser through a PVC pipe. It is like an underground grid of PVC pipes. I wanted to use the irrigation main trench to save on trenching if possible.
Getting back to main question: What do you think about PVC pipe spacing in a trench?
Old 04-09-2013, 06:23 PM   #5
Rewards Points: 6
I can't picture what you would have in one trench together. The PVC fittings will provide some spacing. Give yourself at least 2 inches between pipes. PVC is easy to work with and it cuts easily. If you ever had to repair a pipe, they have slip couplings that you can use for repair.
Dan
Old 04-09-2013, 08:10 PM   #6
Make sure you backfill with sand and pack it then fill the ditch.
Old 04-09-2013, 10:15 PM   #7
Master Plumber
Javiles's Avatar
Rewards Points: 984
Cant say in your area down here we need min, 4 inches around each pipe packed in clear clean fill
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 04-10-2013, 03:28 PM   #8
Rewards Points: 18
Thanks everyone
Cutting and gluing PVC pipe to washer steve3847 Plumbing 8 10-03-2012 09:00 AM
Wood-burning stove...connecting stovepipe to ceiling support box Laura J. Building & Construction 23 12-26-2011 01:49 AM
Qs about the 1/2"dia brass pipe we bought smoochas Plumbing 10 02-21-2011 10:23 AM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 02:05 AM
Backpitched Cast Iron Pipe in Basement....uggh.. apunaha23 Plumbing 5 02-02-2011 02:42 AM
