PVC Pipe Sleeves?? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-28-2012, 09:03 PM   #1
PVC Pipe Sleeves??
Hi All,
I searched and didn't seem to find an answer to this question:
I'm finishing my basement and need to move my kitchen sink drain line from the floor above. I noticed that in the places where the 1 1/2" pvc runs horizontally, the pvc pipe has a 2" pipe sleeve around it as it runs along my floor joists and through some wall studs.
What is the purpose of the pipe sleeve? I'm just trying to determine whether or not I need to use one where I'm re-routing the line.
Thanks!
Jeff
bergsj is offline   Reply With Quote
Old 12-28-2012, 09:34 PM   #2
Rewards Points: 13,968
Got a picture I've never seen a sleeve used.
Old 12-28-2012, 10:30 PM   #3
could it be couplings?
Old 12-29-2012, 06:33 AM   #4
Sure - here is a picture.
Old 12-29-2012, 07:06 AM   #5
Rewards Points: 3,130
That is very strange. Never seen anything like it before, and have no idea why it was done that way.
Where are you located? Could be some local code requirement.
Old 12-29-2012, 08:52 AM   #6
I'm in Chaska, Minnesota. Yeah, I was thinking it must be some kind of code requirement. I'll check with the city...
Old 12-29-2012, 10:10 AM   #7
Master Plumber
Javiles's Avatar
Rewards Points: 996
Looks like some kinda protection the pipe is too close to the edge of the studs, what it would need for protection are metal stud guards, or maybe some one just had an extra piece of pipe they didn't know what to do with??
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 12-29-2012, 10:32 AM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 796
Odd. You'd get canned for that around here. I wonder if someone had squeaky pipes before. Is this a way to stop expansion squeaks?
Best way to join Poly pipe, for a water pipe repair. carl1864 Plumbing 10 11-03-2014 12:31 PM
Removing pipe wrap around copper pipe steve3847 Plumbing 1 12-25-2012 02:46 PM
Qs about the 1/2"dia brass pipe we bought smoochas Plumbing 10 02-21-2011 09:23 AM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 01:05 AM
