PVC Pipe Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-08-2008, 09:01 AM   #1
PVC pipe leak
Hello, This is my first post so be gentle. One of the fittings on the washer drain outlet to the main outlet is leaking and loose. Can I just pull it apart and prime/re glue it? Thanks
JohnJak is offline   Reply With Quote
Old 07-08-2008, 09:15 AM   #2
Registered User
Termite's Avatar
Howdy JohnJak.
If the plumbing is PVC, that's strange that it is loose. Do you think that someone forgot to glue it? If you're able to take it loose and determine that it isn't broken somehow, and it it will go back in cleanly, there's no reason you can't re-glue it.
Use primer and then glue, just like you said.
Old 07-08-2008, 09:27 AM   #3
Thanks for the comeback. I am now going down in the crawl space to fix it. I might be able to pull it back bout an inch or so to make a glue job. It's at a very awkward spot to work(no room) at the fitting. I really don't want to rip the entire junction area apart(big job).
Pipe coming out of wall too long, causes leak GooperMC Plumbing 7 04-17-2008 05:11 PM
water leak around septic pipe gvanhoven Plumbing 2 04-13-2008 11:29 PM
pipe leak & sheetrock damage santogr General DIY Discussions 2 03-04-2007 02:44 PM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 01:08 AM
Leak at flange and drain pipe tallycat77 Plumbing 1 07-26-2005 09:32 PM
