Pvc Pipe And Footing - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-11-2013, 10:10 PM   #16
Doing it myself
Alan's Avatar
Rewards Points: 2,086
"SLEEVES SHALL BE PROVIDED TO PROTECT ALL PIPING THROUGH CONCRETE AND MASONRY WALLS AND CONCRETE FLOORS"
"EXCEPTION : SLEEVES SHALL NOT BE REQUIRED WHERE OPENINGS ARE DRILLED OR BORED"
UPC 313.10.1
Journeyman Plumber
Old 04-12-2013, 11:39 AM   #17
Roofmaster
Rewards Points: 2,172
The reasons that I spec schedule 40 galvanized steel pipe for sleeves are:
1. Steel is close to concrete in its rate of response to thermal change, the grout used to set a steel sleeve will not separate from the masonry like it will when a plastic sleeve is used.
2. Will schedule 40 Galvanized steel rust out? I guess it could in about 356.7 years. I wont be around to see it.
3. Steel does not melt in the event of fire, producing toxic gasses. PVC does.
Old 04-12-2013, 08:14 PM   #18
Concrete & Masonry
Rewards Points: 548
From a stuctural standpoint, the concrete footing isn't going to care if you sleeve or not. Generally, you can take the entire top half of the footing without causing undo weakness to the footing itself. There's hundred's of thousands of basements here with 4" outside diameter cross bleeders every 8-15', with no issues at all..........
jomama45 is offline   Reply With Quote
Old 04-12-2013, 09:52 PM   #19
Doing it myself
Alan's Avatar
I would like you to retract # 3 in regards to pvc pipe passing through said sleeve.
Journeyman Plumber
Digging footing pads, abandon sewer pipes and moldy dirt WillK General DIY Discussions 0 10-08-2011 10:14 PM
Water supply line runs through footing site WillK Building & Construction 19 03-15-2011 01:39 PM
perforated wall drain pipe amakarevic Building & Construction 3 11-01-2010 06:56 PM
How does drain pipe around foundation footing end? pttcc Building & Construction 2 09-19-2010 08:46 AM
What pipe to use? BumperCrop Landscaping & Lawn Care 9 12-25-2009 05:17 PM
