Old 06-08-2010, 02:28 PM   #1
pvc pipe disassembly
pvc pipe disassembly after glue dries
gmouton is offline   Reply With Quote
Old 06-08-2010, 04:42 PM   #2
A "Handy Husband"
rjniles's Avatar
If that is a question, cut out the fitting and start over.
Coastal South Carolina
Old 06-08-2010, 09:52 PM   #3
Doing it myself
Alan's Avatar
X2. The point of PVC glue is that Ayuh... it won't come apart.
Journeyman Plumber
Alan is online now   Reply With Quote
Old 06-09-2010, 06:45 AM   #4
Master General ReEngineer
Bondo's Avatar
Ayuh,.... Unlike Love,.... Glued PVC, Is Forever...
Cut out that section,+ Start Over...
Been to Maine lately Alan,..??
Old 06-09-2010, 09:41 AM   #5
Time to pull out the saw. The glue makes a permanent bond that is almost like a weld.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 01:03 PM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 06:40 PM
Furnace Venting Requirments jamiedolan HVAC 9 11-18-2008 06:40 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
