PVC Pipe & Cold Weather - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-11-2010, 10:16 AM   #1
Question
PVC pipe & cold weather
Hi all, my question is the pipe going to my outside faucet burst last week due to a draft in the foundation. there is a spot up further in the line where i plan on putting in a shut off valve but i'm worried about the weather & glue drying time or if it will hold at all. the pipe is 1/2 inch and the weather tomorrow is calling for 30-40 degrees. is there some type of chart showing drying times?
thanks for any info.
Bernie
Bernmeister is offline   Reply With Quote
Old 01-11-2010, 10:22 AM   #2
You should install a frost free spigot/setup to prevent the problem from happening
Old 01-11-2010, 10:51 AM   #3
Thanks for the info Dave, but for now i just want a shut off valve as this pipe isnt routed right & i would just as soon block the water going to it. where i plan on installing the valve is in a pretty insulated area but will opened up while i'm gluing the pipe hence my question.
thanks again
Bernie
Old 01-11-2010, 11:25 AM   #4
Rewards Points: 3,130
Try reading the label on a can of PVC cement. That might tell you what you need to know.
Old 01-11-2010, 11:37 AM   #5
Here is a link with drying times at different temps
Appears 30f is the Min temp needed
http://www.ehow.com/about_5531523_cu...vc-cement.html
Sump pump discharge pipe: the standing water trap! Deck Plumbing 7 05-19-2009 11:53 PM
Cold weather concrete - Curing questions DigitalFusion Building & Construction 19 11-20-2008 03:27 AM
Underground orangeburgh pipe leading to storm sewer is blocked somewhere flashme18 Plumbing 10 07-21-2008 11:48 PM
Hello from Indiana! Irishking23 HVAC 17 01-17-2008 05:49 PM
