Pvc Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-13-2016, 10:43 PM   #1
Rewards Points: 2
Question
pvc pipe
I have a small project involving pvc pipe. For economy purpose, can a tube cutter [copper tubing] be used instead of a pvc cutter [snip]?
4schmerb is offline   Reply With Quote
Old 01-13-2016, 11:02 PM   #2
Civil Engineer
Rewards Points: 4,560
You can cut PVC pipe very nicely on a chop saw, or a table saw, or with a handsaw if you have a steady eye.
Daniel Holzman is online now   Reply With Quote
Old 01-13-2016, 11:07 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,110
Yes, it 'will' work. But it will be slower than the methods Daniel posted.
The Following User Says Thank You to ddawg16 For This Useful Post:
4schmerb (01-14-2016)
Can't drain water from water pipe to outside faucet hansim4 Plumbing 19 02-23-2015 03:07 PM
Deep Pipe Clog - Epic Battle Digi Plumbing 37 02-02-2013 12:48 PM
Removing pipe wrap around copper pipe steve3847 Plumbing 1 12-25-2012 03:46 PM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 02:05 AM
