PVC Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-20-2011, 10:38 PM   #1
PVC pipe
Do you have to use primer with PVC cement?
Railtail is offline   Reply With Quote
Old 06-20-2011, 11:43 PM   #2
Do something
D'Brie's Avatar
I always do. Makes a better joint and some jurisdictions require it's use per code.
D'Brie is offline   Reply With Quote
Old 06-20-2011, 11:44 PM   #3
Rewards Points: 1,088
It is recommended, but a lot of plumbers don't use primer for joints in low flow applications such as condensate drain lines
handy man88 is offline   Reply With Quote
Old 06-21-2011, 10:32 AM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Local code requires the use of primer.
EXCEPTION :
PVC DWV pipe and fittings MAY BE joined without the use of a primer.
Journeyman Plumber
Old 06-21-2011, 11:01 AM   #5
the Musigician
DangerMouse's Avatar
EXCEPTION :
EXCEPTION to the EXCEPTION: Be sure to check with your plumbing inspector!
Mine said I HAD to use primer on all of my drain work!
Imagine my anger had I not used primer and had to tear it all apart!!! CHECK FIRST!!!
DM
Best way to join Poly pipe, for a water pipe repair. carl1864 Plumbing 10 11-03-2014 01:31 PM
Well pipe access shutdown HomerRepair Plumbing 6 03-08-2011 10:22 AM
Qs about the 1/2"dia brass pipe we bought smoochas Plumbing 10 02-21-2011 10:23 AM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 02:05 AM
First Furnace Install - Need Some Help Getting Started hartkem HVAC 17 10-11-2008 12:55 PM
