PVC To PEX Connection? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-18-2008, 05:48 PM   #1
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
PVC to PEX connection?
What is the best method to connect 1/2" PVC shedule 40 to 1/2" PEX?
My first thoughts are:
PVC female adapter to PEX male thread/barb fitting
or
PVC male adapter to PEX female thread/ barb fitting.
Is one better than the other or is there a better way?
Old 08-18-2008, 06:20 PM   #2
Registered User
Termite's Avatar
Either way would work fine. Personally, I'd opt for the female PVC and the male hose barb PEX fitting. Haven't seen a female thread/PEX barb fitting but they probably do make it.
Old 08-18-2008, 10:50 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Not sure what type of pex you are using, but all of our IPS adapters are brass, and threading a male brass (or any metal) into a plastic female fitting is a big no-no, I believe even the codebook (UPC) states this, or has in the past anyway.... I wouldn't do it even if it was code approved. Always male plastic into female brass (or other metal).
We use the wirsbo/uponor style of pex, and they do make brass female adapters. Not sure how readily available they are to public, but..... they are out there.
edit : here are the style we use, and IPS adapters are only available in brass.
http://www.pexsupply.com/categories....D=540&brandid=
Journeyman Plumber
Old 08-18-2008, 11:21 PM   #4
Registered User
Termite's Avatar
I didn't realize that. I'll have to do some reading to see if it is still prohibited. Sorry for the bad info.
Deck Beam connection to Post? CNJHomeowner Building & Construction 7 08-08-2008 07:14 AM
Wall heater connection to breaker mw6263 Electrical 2 06-22-2008 11:47 AM
sub panel connection rtyui2 Electrical 6 11-28-2007 05:24 PM
Post to Piling connection george514 Building & Construction 4 06-07-2007 11:23 AM
Bathtub drain and w&O overflow connection Manuel6 Plumbing 5 11-03-2006 12:23 PM
