PVC Leaking, Need Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-03-2009, 12:57 PM   #1
PVC leaking, need help
I've done this at least 20 times in my life with no problem. I replaced an outside faucet. The PVC pipes under the house weren't going to fit the new one, so I started over. I had 15 inches starting from the water line with 3/4, ending at a metal male side of the faucet's pipe.
I had to turn off the water, which meant my daughter couldn't take a bath, so I under a time crunch. I put the pvc female 1/2" on the metal pipe, then 3/4" female pvc on the far end. Put the pieces in the middle and was done. Unfortunately I couldn't let the glue set, wife and daughter needed water ASAP. One of the glue fittings leaked, but stopped for the most part. But, the to ends (female) still leak.
CAN i tighten them and not have to start this B.S. all over again? Or am I S.O.L.?
mikeinvirginia is offline   Reply With Quote
Old 04-03-2009, 01:06 PM   #2
47_47's Avatar
Rewards Points: 62
Sorry Mike, you're SOL. Trying to tighten it will probably cause a bigger leak.
47_47 is offline   Reply With Quote
Old 04-03-2009, 01:12 PM   #3
Yeah, that's what I thought. I might just do it nice and easy I only have to get the male end around twice or one and a half turns to get the drip to stop I think. I hope I can do it without screwing the whole thing up even worse.
Old 04-03-2009, 01:45 PM   #4
47_47's Avatar
Rewards Points: 62
Can you cut the pipe, tighten the threaded connections and glue on a shut off or coupler to repair the pipe?
I'd have enough supplies on hand if you had to redo the entire setup.
Old 04-03-2009, 02:21 PM   #5
HVAC / Plumbing
Red face
May as well do a proper repair now.2nd. Time around. So, you won't have to do it a 3 rd. Time
kenmac is offline   Reply With Quote
Leaking Shower Faucet sprtnfan Plumbing 2 12-20-2008 11:08 AM
Ice and Water Shiled over or under Drip Edge? Leaking Roof sbt3 Roofing/Siding 8 05-02-2008 11:00 PM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 08:53 PM
water leaking from pressure balance spool lauralyn1 Plumbing 16 08-13-2007 04:50 PM
leaking bathtub mikeynholly Plumbing 1 02-11-2007 01:50 PM
