#1 |
PVC joint basic question
I am building a paver patio in my backyard and I am burying a 3/4" PVC pipe for irrigation water under the sub base of the patio. There was a straight joint that I could not push in all the way. It's about half way in and I then I couldn't push it in any more. I did manage to turn close to 1/4 turn before it stuck there.
After a few hours of letting it cure, I capped the other end of the pipe and let water through it. No leak for like 20 minutes. Not a single drop. But since this joint is right beneath the patio and once the paver patio is built, it's not easy to dig things out again. So, should I be worry about this joint that has the pipe only half-way pushed into the socket? Thanks! |
#2 |
Remodeling Contractor
I would fix it right. It will eventually leak otherwise
#3 | |
MarginallyQualified
PVC joint basic questionQuote:
it would be bad enough if you didn't know it was wrong and it later fails on you But to know in advance and not do a $2 twenty minute fix? That's crazy talk. dig the soil back, cut the pipe at both ends of the bad joint, set new pipe of the correct length with a coupling at each end. |
| Display Modes | |
| The most basic question on this forum | dcponto | Electrical | 8 | 08-23-2011 09:05 PM |
| basic code question | deko | Electrical | 3 | 01-13-2011 02:26 PM |
| VERY basic ceiling framing question | artlover13060 | Carpentry | 14 | 12-28-2009 07:51 PM |
| joint compound question | golfer | General Discussion | 3 | 01-09-2006 07:19 AM |
| Some basic question about roofing help! | motd0iyeuem | Roofing/Siding | 6 | 12-19-2005 08:15 AM |
