Pvc Gold??? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-06-2011, 07:36 PM   #16
HVAC / Plumbing
Originally Posted by DangerMouse View Post
What does the UPC say IS the right tubing to use? Is PVC "GOLD" one of the options?
DM
I think he may be getting you on the temp rating. CPVC is rated for hot water. PVC isn't. Here we have to use CPVC for T&P
kenmac is offline   Reply With Quote
Old 01-06-2011, 07:38 PM   #17
the Musigician
DangerMouse's Avatar
I _HAVE_ 3/4" cpvc... he said it has to be 'gold'. Can you quote code #s on this one so I can ask him?
DM
Old 01-06-2011, 07:55 PM   #18
i think it was said earlier, but flowguard gold is just a brand name of CPVC. All CPVC has a gold/cream color, so if you have cpvc on it you'll be fine. if he wants a certain brand, you'll have to ask him for that code section. as for my code sections, 604.1 deals with materials, and 608.5 deals with relief valve drains.
the_man is offline   Reply With Quote
The Following User Says Thank You to the_man For This Useful Post:
DangerMouse (01-07-2011)
Old 01-07-2011, 06:54 AM   #19
the Musigician
THAT'S what I needed, Thanks TM!
DM
Old 01-07-2011, 07:22 AM   #20
Rewards Points: 1,216
DM
I would do the reseach as you are for my own info but then.
Just put in what the man is asking, for a couple bucks forgetaboutit.
COLDIRON is offline   Reply With Quote
Old 01-07-2011, 07:37 AM   #21
the Musigician
Yeah, but when you're as poor as we are..... a couple bucks means a lot!
I'm sure he'll be OK with cpvc "unbranded" if I can quote UPC. Maybe that's the most common brand he sees?
DM
Old 01-07-2011, 08:45 AM   #22
all that the inspector would be able to say about what you have installed is that your stuff isn't listed like floguard is. in my code book cpvc is listed as ASTM D-2846-97. it'll say on the pipe what the listing requirements are. show the inspector and he won't be able to say a thing. googling your lat/long put you somewhere in michigan?? which i don't believe use the upc, so code references from me probably won't mean anything, but listing #'s i believe are the same
Old 01-07-2011, 08:50 AM   #23
the Musigician
long/lat is actually 3,000 feet above the Kalamazoo/Battle Creek airport...
They won't let us land.... they know I'm on the plane.
DM
Old 01-07-2011, 09:46 AM   #24
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,262
Originally Posted by the_man View Post
don't know about your code, but I use the UPC and it states 604.11.2 Water Heater Connections. PEX tubing shall not be installed within the first 18" of piping connected to a water heater.
Not all states use UPC (less than half). PEX manufacturers say it can connect directly to a WH.
States that use the UPC
Alaska UPC adopted at State level but IPC in use locally
Arizona UPC adopted at State level but IPC in use locally
California UPC applicable Statewide
Colorado UPC adopted at State level but IPC in use locally
Hawaii UPC, with local ammendments.
Indiana UPC base document for State code
Iowa UPC effective Statewide, IPC adopted by Local Governments
Kansas UPC adopted at State level but IPC in use locally
Minnesota UPC effective Statewide(1)
Missouri TBD either IPC or UPC effective Statewide
Montana UPC effective Statewide
Nebraska UPC adopted at State level but IPC in use locally
Nevada UPC adopted at State level but IPC in use locally
New Mexico UPC adopted at State level but IPC in use locally
North Dakota UPC effective Statewide
Oregon UPC effective Statewide
South Dakota UPC 2003 version effective Statewide
US Virgin Is. UPC Island wide
Washington UPC effective Statewide, with amendments
Wyoming Both IPC & UPC used by Local Governments
Coastal South Carolina
Old 01-07-2011, 11:56 AM   #25
DM
hahaha time to pull a D.B. Cooper and ask for a parachute
Old 01-07-2011, 12:03 PM   #26
the Musigician
I did, they won't give me one..... but they said they'd be happy to open the hatch for me anyway.
DM
Old 01-07-2011, 04:42 PM   #27
The inspector can kinda say anything he wants. Don't want him snooping around too much. Just comply and that's all there is to it. Think about the issue it's over a stupid little T/P line discharge time for Danger to just DO IT.
Old 01-07-2011, 05:00 PM   #28
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
he is trying but DM complying with the inspectors requirement is like you using a flibbergast to get to work. If it doesn't exist, you just can't do it.
Old 01-07-2011, 05:14 PM   #29
the Musigician
I HAVE to comply... I want my darn green stickers and then the inspectors to GO AWAY! LOL
THEN I can get to finishing all the little things like trim and baseboards that take time but don't need to be INSPECTED!
I just needed to know if he just recognized that brand as cpvc and just calls it that or if any brand cpvc will do.
He chided me on calling the bathroom sinks bathroom sinks and the toilets toilets!!!
DM
Old 01-07-2011, 05:18 PM   #30
Dang....what did he want you to call them ?
Dal Tile Gold Nugget Q Ineedhelp2009 Flooring 2 08-01-2009 11:55 AM
How do I repair a broken towel rack that was attached to the tile? meganprncss General DIY Discussions 2 05-03-2009 09:40 AM
satin nickel - the new <faux> gold? joeyboy Interior Decorating 13 10-10-2007 04:30 PM
