PVC Flange To ABS Pipe? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-20-2013, 11:39 AM   #1
Trucon01's Avatar
Rewards Points: 510
PVC flange to ABS pipe?
Hi All,
I'm trying to replace my closet flange. I have a 3" ABS pipe with the current flange secured to the outside of the pipe.
Should I cut open the sub floor, cut off the 3" ABS, add a 4" to 3" coupler and use 4" PVC to the floor? That way I can get 4" inside flange...
I ask because I would only be able to use a 3" inside flange which I read wasn't that great.
Jeff
PVC flange to ABS pipe?-photo-2.jpg   PVC flange to ABS pipe?-photo-1.jpg   PVC flange to ABS pipe?-photo-3.jpg
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 02-21-2013, 11:25 AM   #2
Trucon01's Avatar
Rewards Points: 510
Can anyone help? I'd like to stop on my way home from work to get what I need
Old 02-21-2013, 12:54 PM   #3
Rewards Points: 12
I would not mix ABS and PVC. They have different solvents although there is one that can be used for both.
I don't see the need to use a 4" pipe. The toilet outlet is probably less then 3".
djlandkpl is offline   Reply With Quote
Old 02-21-2013, 01:25 PM   #4
Trucon01's Avatar
Rewards Points: 510
Not even a 4" to 3" furco?
Old 02-21-2013, 02:25 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 452
Why not a standard 3" female ABS flange?
Old 02-21-2013, 02:38 PM   #6
Trucon01's Avatar
Rewards Points: 510
I guess I'm confused on the 3" flange. The current flange is on the outside of the 3" ABS pipe. How would I take off the current flange and just put on the new female?
I assumed I would have to cut the below where the flange sits, then couple the 3" ABS and bring it back up again to tie into the new flange?
Old 02-21-2013, 02:54 PM   #7
Rewards Points: 12
Yes, that's how I see it. They sell a cutter that attaches to a drill and cuts from the inside. Add a coupler, piece of pipe and flange.
Old 02-21-2013, 03:03 PM   #8
Plumber
Rewards Points: 452
Thats the best way. Cut down low, glue on a coupling. Measure what you cut out and adjust the length to allow for any change in floor height, glue in the riser. Repair the floor and add new flange.
That inside cutter is a nice tool. Be sure to stuff a rag down the pipe- I've seen that saw fall out of the drill chuck more then once. You don't want to try and retrieve it from the base of your stack
Old 02-21-2013, 03:57 PM   #9
Like Eplumber said. 3" female flange. Aren't you going to have to cut the subfloor out anyway to put a new piece of plywood in that will butt up closer to the flange so you have something to screw it into? 3" flange/pipe is fine especially with today's 1.6 gallon flush toilets. Also, I've never had any problem joining PVC to ABS. I'd rather glue it than use a fernco if you have no future access to it. I do trust fernco's too ......
Greg761 is offline   Reply With Quote
need advice on replacing closet flange gps4 Plumbing 6 10-31-2012 05:34 PM
Cutting and gluing PVC pipe to washer steve3847 Plumbing 8 10-03-2012 09:00 AM
toilet flange question donkeyk Plumbing 15 02-01-2012 07:46 PM
closet flange for cast iron pipe tomknox Plumbing 26 01-21-2012 12:05 PM
toilet flange connection to lead soil pipe rd115 Plumbing 1 11-22-2009 06:37 PM
