PVC Fittings - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-06-2010, 07:02 AM   #1
PVC fittings
Are PVC compression fittings and dresser couplings the same thing
Dave Christians is offline   Reply With Quote
Old 11-06-2010, 08:03 AM   #2
Civil Engineer
Rewards Points: 4,938
A dresser coupling refers to a class of fittings that typically include a rubber boot on each end, and a steel band clamp to cinch up the boot. A compression fitting is completely different, typically you see them in water stops. Compression fittings include a ring (typically metal) that gets compressed around the pipe, and the ring fits into a beveled seat, forming a liquid tight seal.
New House + PEX + Plastic Fittings = ? GaryZ Plumbing 22 01-06-2011 08:47 AM
Problem joining copper fittings after fluxing. mikeg12 Plumbing 7 09-23-2010 12:29 PM
remove compound from brass fittings to unscrew fittings purpleheart Plumbing 3 05-08-2010 06:49 AM
Sharkbite brand PEX fittings at Home Depot rjniles Plumbing 1 03-16-2010 07:33 PM
iron pipe fittings farrington135 Plumbing 1 07-13-2007 08:16 PM
