Is PVC Drain Pipe A Pressure Pipe ? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-22-2011, 02:15 PM   #1
Rewards Points: 87
Is PVC drain pipe a pressure pipe ?
I guess the drain pipe is not under pressure but better to ask pros here to make sure ...
I got this PVC glue for conduit solvent cement (do not use for pressure pipe) for conduit project and wonder if I should get the purple primer/cement combo instead so I can use on both water pipe and conduit down the road as I only have a dozen of conduit joints to glue atm.
A picture is worth a thousand words.
Stephen S. is offline   Reply With Quote
Old 04-22-2011, 05:37 PM   #2
Rewards Points: 3,130
The cement for conduit will NOT work for PVC pipe. It's not expensive; use the right stuff.
The Following User Says Thank You to md2lgyk For This Useful Post:
breid1903 (04-23-2011)
framing around drain pipe in basement griffinst Carpentry 5 03-25-2011 06:34 AM
drain pipe from HVAC in attic dripping on to sheetrock gnostic19 HVAC 7 03-22-2011 03:05 PM
Basement drain pipe "pit" ground water fix. alecmcmahon General DIY Discussions 13 12-01-2010 05:42 AM
Replacing corroded metail drain pipe gschulte Plumbing 2 09-19-2010 08:21 PM
Drain Pipe MrMrsSip Plumbing 2 11-21-2008 05:46 PM
