-   -   Is PVC drain pipe a pressure pipe ? (http://www.diychatroom.com/f7/pvc-drain-pipe-pressure-pipe-102401/)
Stephen S. 04-22-2011 03:15 PM
I guess the drain pipe is not under pressure but better to ask pros here to make sure ...
I got this PVC glue for conduit solvent cement (do not use for pressure pipe) for conduit project and wonder if I should get the purple primer/cement combo instead so I can use on both water pipe and conduit down the road as I only have a dozen of conduit joints to glue atm.
md2lgyk 04-22-2011 06:37 PM
The cement for conduit will NOT work for PVC pipe. It's not expensive; use the right stuff.
