Pvc Drain Pipe Joint Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-27-2009, 06:37 PM   #1
pvc drain pipe joint leak
Hi all,
I have a leaking pvc drainpipe in my home basement. It is a slow drip from where two pipes are connected to one another. How do I disconnect the joint and re-cement? It is part of the home drain pipes in the basement. Or, what other options are there to fix the leak? Thanks.
jp
nytstyk is offline   Reply With Quote
Old 12-27-2009, 09:54 PM   #2
I do not think you can really disconnect exactly at the joint. It is a lot of work. The cement must be very hard to clean, although there are some solvents to clean the cement and glue it again. I think it is better to cut
the portion of pipe where the leak is and assemble with new pipes.
Gabriel24 is offline   Reply With Quote
Old 12-28-2009, 01:05 AM   #3
Irrigation Contractor
Location: South Central British Columbia - The great White North
To repair a leaking PVC pipe or fitting properly - cut it out and replace. Don't forget to ream/bevel the pipe on the outside, and use primer.
Mick
Water Guy is offline   Reply With Quote
sewer backup and stench jayhill Plumbing 12 08-14-2008 12:06 AM
washer drain pipe paydelady Plumbing 3 11-13-2007 01:27 AM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 01:08 AM
Leak at flange and drain pipe tallycat77 Plumbing 1 07-26-2005 09:32 PM
