PVC Drain Pipe Banging Against Stud - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-31-2010, 09:17 PM   #1
Rewards Points: 85
In my finished basement, there is a vertical PVC drain pipe in the wall that makes a banging noise when hot water makes it expand. The pipe is rubbing against a stud and bangs against it. What's the best way to fix this problem? Clamp the pipe more tightly against the stud, or try to stop it from contacting the stud (if possible). Or something else?
MrBill_DIY is offline   Reply With Quote
Old 11-01-2010, 06:04 AM   #2
Clamps restrict natrual expansion/contraction if too tight. Wood shims often help.
Old 11-02-2010, 06:45 PM   #3
Rewards Points: 85
How would putting shims between the PVC pipe and the stud help? Wouldn't that just cause the pipe to rub against the shims?
Replacing corroded metail drain pipe gschulte Plumbing 2 09-19-2010 08:21 PM
Is yellow polyethelene or polyphenol gas pipe now the preferred gas conduit? MarkSilber Plumbing 1 09-18-2010 12:10 PM
Sink drain for new sink. Can't get to plain pipe. rogersmithiii Plumbing 2 07-10-2009 10:24 AM
New bathroom drain pipe leaks PAK Plumbing 2 07-29-2008 09:36 AM
washer drain pipe paydelady Plumbing 3 11-13-2007 12:27 AM
