PVC Cutter Issue? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-06-2013, 12:00 AM   #1
Rewards Points: 280
PVC cutter issue?
In 1999 I purchased a PVC cutter at a big box store. It is a small ratcheting type for up to maybe 1 1/2 inch, red with no name on it.
It has not had much use, I doubt if I have made 200 cuts with it over the years.
Today I noticed it does not cut square. The cut is straight, but not square. It is not off a lot but it is noticeable to the eye, on a 3/4" pipe it is off about 3/32" side to side.
Is this normal, am I doing something wrong, time for a new cutter? JIm
jjrbus is offline   Reply With Quote
Old 05-06-2013, 07:11 AM   #2
Rewards Points: 3,130
I've never used one of those things. The same tubing cutter used for copper pipe works just fine. If you have one of those, try it and see.
Old 05-06-2013, 09:01 AM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
They do that after a while. I try to rotate mine halfway around the pipe while applying gentle pressure to score it before I go mashing the blade all the way through it. It helps a lot.
3/32 in the scope of a pvc joint isn't really horrible.
Journeyman Plumber
Old 05-06-2013, 09:14 AM   #4
Rewards Points: 280
Thanks for the responses. I am not sure if it has always been like this and I did not notice or it happened over time.
Not sure of the slop tolerance in PVC I touched them up with a file. Will try the scoring next time. JIm
Old 05-06-2013, 05:47 PM   #5
Rewards Points: 582
even if its not square...no big deal...your not building a watch....ben sr
Trane XR90 issue jasun HVAC 7 10-08-2012 06:18 PM
HVAC condensor fan outside intermittant wheelsup HVAC 21 05-24-2012 10:25 AM
Westinghouse furnace issue joe8918 HVAC 9 12-04-2011 05:50 PM
how to reduce mositure issue on basement? diy001 Building & Construction 0 10-28-2011 12:44 PM
Perplexing AC issue AvalonGirl HVAC 22 08-17-2011 06:49 PM
