Pvc? Cpvc? SCH 40??? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-12-2010, 10:43 AM   #1
the Musigician
DangerMouse's Avatar
pvc? Cpvc? SCH 40???
The old drains I'm tearing out and replacing are a combination of all different pipes. What is code as pertaining to drainpipes? I see black 1" sch40 for the venting, attached to pvc drain lines etc. Some were not even glued, just stuck in place! (with wrong sizes, no less, that evidently did not work properly without the INNER TUBE pieces they had stuck in them....lol)
DM
Old 07-12-2010, 11:25 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Someone tried to use black plastic ABS pipe with white plastic PVC pipe.
Each has a separate "glue" made to chemically "weld" its fittings and pipe together, and there also is a special "glue" that can be used to fuse the two different types together...IF they fit due to pipe thickness.
Either and both can be used for residential drain/waste/vent systems.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 07-12-2010, 12:42 PM   #3
the Musigician
Good.... I thought so... I have a bunch of pvc, so I'll use that for the venting as well.
DM
Cpvc!? LateralConcepts Plumbing 6 06-22-2010 09:44 AM
help pvc & cpvc or metal pipe? ok_cntrygrl7 Plumbing 0 05-11-2010 02:18 PM
Confused about Pex tubing and cpvc staceythalmann Plumbing 3 05-28-2009 07:19 PM
burying CPVC under concrete amakarevic Plumbing 17 03-25-2008 08:45 AM
How to connect non-threaded 1/2 inch CPVC to a compression shut-off valve andy Plumbing 6 12-12-2006 09:02 PM
