Pvc/cpvc Determining Difference? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-01-2013, 05:38 AM   #1
Rewards Points: 280
Pvc/cpvc determining difference?
I need to tee into the 3/4" main water line,plastic pipe coming into the house that is buried underground, after the meter of course.
I do not see any markings on it? So how would I know if it is PVC or CPVC? This is in SW FL, the house is 25 years old but was originally on well and later changed to city water, so I do not know how old pipe is.
If I cannot tell the difference what would be the best type of T to use? JIm
jjrbus is offline   Reply With Quote
Old 05-01-2013, 06:17 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
Typically this would be PVC.
Measure the OD of the pipe. Go fo a home center and compare to the OD of PVC and CPVC. Hint, they are different, PVC is
larger.
Coastal South Carolina
Old 05-01-2013, 06:25 AM   #3
Rewards Points: 3,130
Probably difficult to tell with pipe that's been underground, but PVC and CPVC are slightly different colors.
Old 05-01-2013, 07:37 AM   #4
Master Plumber
Javiles's Avatar
Rewards Points: 996
If its the original line from the home its PVC, 25 years back CPVC was not common in south Florida, anyway pvc white cpvc bone beige type color.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 05-01-2013, 11:47 AM   #5
Rewards Points: 280
Thanks for the responses! Much ado about nothing though. What I thought was dirt streaks was actually printing, it is PVC. 2nd mistake I made in this century. Thanks again. JIm
What is difference between commercial vs residential HVAC installer? Andee77 HVAC 11 12-23-2015 04:47 AM
voltage difference between legs john68112 Electrical 15 12-17-2010 07:35 AM
Difference in hardwood floors BryantS Flooring 0 10-02-2010 01:17 PM
Mapei ULTRAFLEX 2 VS ULTRAFLEX 3 What's the Big Difference K.M.G Tiling, ceramics, marble 16 04-23-2010 02:18 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
