Old 11-19-2005, 05:26 PM   #1
pvc cement
after installing new pvc drain pipes how long do you have to wait before you can use them? I was under the impression it was about an hour for drain fittings but was told today to wait 24 hours. joe
farrington135 is offline   Reply With Quote
Old 11-19-2005, 08:23 PM   #2
Contractor
pvc cement
Drain pipes should be good to go before you finish hooking them to the fixture/appliance. I repaired an 1-1/4" pressure line yesterday and waited a whole 15 min. before putting it on line. This may be different in colder climates.
Teetorbilt is offline   Reply With Quote
Old 11-20-2005, 08:59 PM   #3
Long-Time DIYer
Mike Swearingen's Avatar
pvc cement
Since you're only installing drain pipes (zero pressure), you should be good to go as soon as you make them up.
I also only wait about 15 minutes for pressurized supply lines, although some recommend the 24 hours.
Mike
Mike Swearingen is offline   Reply With Quote
Old 11-27-2005, 04:28 AM   #4
747
registered
747's Avatar
pvc cement
pvc cement. Different codes apply to pvc cement. Meaning some will allow clear but other require the purple pvc cement. My town allows clear. But other towns require the purple so the plumbing inspector can see the cement was applied.
747 is offline   Reply With Quote
Roll Roofing Repair IfItAintBrokeFixItAnyway Roofing 9 09-13-2009 06:32 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Fence problems-Cement or No Cement WBMill Landscaping & Lawn Care 8 06-17-2007 03:36 PM
Cement Patio Deteriorating..? DeepDish Building & Construction 6 05-09-2007 11:03 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
