Pvc To Cast Iron - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-01-2010, 03:59 PM   #1
pvc to cast iron
hello. I have a 2" cast iron female drain pipe under the kitchen sink which has seen better days. When attempting to snake the drain, I ripped off the male threaded pvc that was connected to it. I went to replace the assembly and the threaded male pvc does not screw into the female CI correctly (I have no idea how it never leaked in the first place).
Anyway, I am proposing the following and an looking for suggestions/thoughts.
1. attach a 2" galvanized close nipple to the threaded CI drain with dope. For some reason, the threads on the GV nipple screw in nicely where the PVC did not.
2. use a frenco 2" to 2" to connect the THREADED close nipple to the pvc. Will a fernco work correctly on the threaded pipe?
Thanks.
adoner is offline   Reply With Quote
Old 02-01-2010, 04:44 PM   #2
Remodeling Contractor
I would not use a galvanized nipple. find out why the PVC will not screw in... threads are the same. Or if all else fails a brass nipple and a fernco.
Old 02-01-2010, 05:08 PM   #3
Licensed Master Plumber
Yep, run a 2" tap through the threads to straighten them out and go back to PVC.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 02-02-2010, 12:34 PM   #4
The close nipple screwed into the drain all the way with no resistance. I have seen other applications where a threaded PVC will not fit a female iron pipe.
pvc to cast iron hub using fernco-can't get it! What have I done Plumbing 10 01-22-2014 07:55 PM
Cast Iron Pipe ehv8trix Plumbing 4 11-25-2009 06:49 PM
working with cast iron ericadami Plumbing 9 11-30-2008 12:45 PM
Cast iron and rusty pipe question snowens Plumbing 2 07-27-2008 10:07 AM
Help with Cast Iron Material Tester Plumbing 2 10-25-2007 10:58 AM
