Old 02-04-2007, 01:29 AM   #1
PVC to Cast Iron
I'm going to vent a fixture. I'm using pvc pipe for the vent and need to connect it into a 2" cast iron hub.
What is the best way to do this? Rubber gasket or led?
oakj is offline   Reply With Quote
Old 02-04-2007, 02:48 AM   #2
jproffer's Avatar
PVC to Cast Iron
They make epoxy (of sorts) to put together PVC and cast. Ask at a plumbing supply house.
jproffer is offline   Reply With Quote
Old 02-04-2007, 08:28 AM   #3
Journeyman Plumber
Ron The Plumber's Avatar
PVC to Cast Iron
If it's just a vent use a 3" x 2" fermco, the 3" side will fit tight over the hub of the cast pipe, you will need to force it on but it will go over the hub.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 02-04-2007, 12:14 PM   #4
jproffer's Avatar
PVC to Cast Iron
Didn't think of that.
Go with Ron's idea. Much easier to work with than that epoxy shi...uhh...stuff.
Cast Iron Baseboard Installation Bob G. HVAC 7 09-15-2009 09:22 AM
Current trends: Cast Iron or Stainless Steel sink? Fat b Remodeling 4 05-04-2007 08:09 PM
Old cast iron pipes heather92 Plumbing 2 04-10-2007 09:36 AM
How to? Cast Iron Stacks. mjnovak77 Plumbing 9 09-14-2006 09:46 PM
